August 25, 2023 at 12:16 pm
SolutionParticipantDescription The attached pdf document explains how a beam object extracted in SpaceClaim can be converted back to a solid geometry. In order to achieve this, the operations Clip with Volume and Extract Geometry have to be used. The pdf document shows first how a beam is extracted from a solid geometry (steps 1-2 of the attached document) and then how the beam is converted back into a solid (steps 3-6).
1. 2050655.pdf
