June 5, 2023 at 7:05 am
FAQParticipantIf you’re encountering the general error even with the models that had worked earlier, chances are that an RSM process was not properly terminated which may be preventing the solver to run anything new. Please try the following steps: – If you have any workbench sessions, please save the model and exit WB. – Open Windows Task Manager and look for the processes Ans.RSM.xxx Manually terminate them. – Open the WB session and open the RBD model that was running earlier and try solving it.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
