How to resolve Class3 Error 2005-13 if it has already occurred in the database? Class3 Error 2005-13 states that if new nodes are defined after an IC command, and those new node numbers are larger than the largest node number that was active when the IC command was issued, the initial conditions input by the second and any subsequent IC commands are not correctly defined for all those nodes with larger node numbers. This Class3 report goes on to give two workarounds that are helpful for cases where this error has not already occurred. However, no workaround is given to help someone who already has this error in their database. What can I do if my database already contains this error?
March 17, 2023 at 9:00 am
FAQParticipantTwo problems occur due to this error: •The displacements and velocities of these new nodes are not initialized to zero •The record size of these new nodes are not correct If the error already is in the database, issuing an ICDELE and then defining new ICs will cleanly correct the error.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
