August 25, 2023 at 12:16 pm
FAQParticipantFor Symmetric Behavior, results are reported for both Contact and Target surfaces. To plot the result for Target surface, Select ‘Contact Tool’ and go to Worksheet. In the Worksheet select ‘Contact Side’ as ‘Target’ for the contact pair. Please refer the attached image. For any Asymmetric Behavior, results are only available on Contact surfaces.
