January 25, 2023 at 7:34 am
FAQParticipantThe main commands and steps used here are: 1. define arrays/tables to hold the source and target data. It’s done through command *DIM 2. read in the source data into a table, then copy temperature and coordinates into two separate arrays. Done through *TREAD and *MFUN 3. map source data to target mesh. Done through *MOPER 4. Once mapping is done, use the *DO loop to apply temperature using BF command
