Tagged: 18, General, mechanical-apdl, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantImport the ds.dat file into APDL and generate the .rst file. Once the .rst file is available read it into Mechanical using ‘Read result files’ option in Tool menu.
