June 5, 2023 at 7:04 am
FAQParticipantIf a symmetry is defined with Z-axis as normal, one can activate Graphical expansion (Beta) into the symmetry folder (not the symmetry region) and request a Cartesian, Half expansion with a tiny negative Delta Z. That will not work with Delta Z = 0
