How to plot Frequency response graphs in harmonic analysis in a local coordinate system using Mechanical?
June 6, 2022 at 9:58 am
FAQParticipantIn Mechanical, Frequency Response graphs are always processed in the GLOBAL coordinate system, even if the nodes are rotated to any local coordinate system.
In Mechanical APDL /POST26 graphs are always in the Solution coordinate system. Nodal quantities are reported in the NODAL coordinate system. If the nodes are rotated to a local coordinate system then /POST26 graphs are in the local coordinate system.
At present, it’s not possible to plot the Frequency response graphs on the local coordinate system, but it’s possible to inset a Command snippet and take a snapshot from /POST26 and make it available in Mechanical as a figure. Alternatively, one can read the .rst into MAPDL and process the model in Mechanical APDL using /POST26.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- Tips about Postprocessing options for Harmonic Solution in Mechanical
