How to pick the value of incompressibility parameter, D, when we want to add small amount of compressibility to the hyperelastic material?
Tagged: 19, hyperelasticity, materials, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe incompressibility parameter, D, is nothing but 2/(initial bulk modulus). If you wish to add small amount of incompressibility (large but finite bulk modulus), then adding a small value for D will do it. Note that the parameter D has the units of 1/stress. So, if the initial shear modulus of the material is, say 2.5 MPa, then a value of 1e-2 MPa^-1 would be a reasonable value for D.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
