How to perform curve-fitting in ANSYS Workbench to calculate Prony series constants for viscoelastic models?
Tagged: 2019 R3, engineering-data, General, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attached video to access the solution.
1. 2061555.mp4
