How to overcome the warning message?: During data mapping, target nodes were found outside the boundaries of the source point data. A different method may have been used to calculate the interpolated value. You can find more information by looking at the Summary comment or by turning on named selection creation for outside nodes to help identify these areas.
Tagged: 17.2, General, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantTo correct the mapping go to: Imported Body Temperature > Mapping Control > Set to Manual Weighting > Distance Based Average (Or other type like Kriging) Re import Temperature Load Examine the Named Selections created and note that no outside nodes exist.
