May 25, 2023 at 7:29 am
SolutionParticipantDerive relative permittivity and conductivity from complex refractive index. Start with complex refractive index to derive the real and imaginary parts of relative permittivity. Use the real part of relative permittivity to define the permittivity of the material and use the imaginary part of relative permittivity to derive the conductivity that you will use in the material definition. See attached for more detail.
1. Complex_Conductivity.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
