How to model heater grid with beam bodies and shared intersection points which is required to simulate heating of a plate from micro-heater grid?
Tagged: 19.2, General, mechanical, modeling-and-meshing, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantPlease refer attached document for details This Solution is created by our channel Partner
1. 2058523.pdf
