March 17, 2023 at 1:11 pm
SolutionParticipantIn some scenarios, it may be advantageous to solve for the primary phase flow field in a single phase solver (Pressure-based or Density-based) and then import the relevant data into the primary phase variables under the multiphase framework. While this does not require any special treatments in some cases (like shifting single phase variables to “shared” field variables in multiphase), it needs a simple workaround to import these values to “phasic” variables in the multiphase setup. This is described in the attached solution document.
1. 2049045.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
