Tagged: 19, General, mechanical, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantTo increase the significant digits, On the Project Schematic page go to: Tools>Options>Appearance>Display>Number of Significant Digits. Then change the default 5 to desired value and restart Mechanical.
