June 6, 2022 at 9:57 am
FAQParticipantThe maximum number of equilibrium iterations per each solution point is 25 based on the default setting of the NEQIT command. To change the maximum number of equilibrium iterations, you can issue the NEQIT command from within a Command Object. For example, issuing NEQIT,30 will increase the maximum number of equilibrium iterations to 30.
