Tagged: 18.2, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThe report generator includes only those objects which are visible in the model tree. The user may filter the tree visibility by Object names so only those which are present in the model tree are included during report generation.
