January 25, 2023 at 7:34 am
FAQParticipantBolt pretension is a loading condition so it is not available in a stand alone modal analysis. However if you wish to study the effects of bolt pretension on the modal characteristics of a model, you can run a pre-stressed modal analysis. The bolt pretension is simulated in the preceding static analysis and you can use pre-stress from static analysis in the modal analysis which will give the modal characteristics based on the bolt pretension.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
