June 6, 2022 at 9:58 am
FAQParticipantThe command MP,VISC can be used to include bulk viscous dissipative effect from fluid for example water or seawater. Note, however, that the bulk dissipation effects are very small in general unless the wave travels a large distance. There may not be much difference after adding MP,VISC for water (or seawater) for relatively short distances. Note that this bulk viscosity term has no effect at FSI locations and does not provide viscous effects at the fluid-solid interface.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
