Tagged: 2020 R1, General, mechanical, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantStep1 : Consider any existing Force deflection curve already as Table in Mechanical Step2 : Use “Export” option to save it as XML file for reuse Step3 : Saving as “one.xml” Step 4: Select all the springs with Shift + Left Mouse button and apply the one.xml with a single mouse click.
1. Solution_2062679.pdf
