General
General
How to import a Zuken .7z file into HFSS 3D Layout?
    • SolutionSolution
      Participant
      Extract .7z and locate odbout directory. Inside of odbout, find the directory which contains layout information. Using 7zip, archive that directory twice as .tar and then .gz, then manually rename the resulting .tar.gz to .tgz. Finally, in Electronics Desktop, use menu option File>>Import>>ODB++ to import into HFSS 3D Layout.
      1. Zuken_ODB_Import.pdf
