June 5, 2023 at 7:05 am
FAQParticipantUse Interference Detection tool(beta) in the Tools Menu > Analysis Tools. It can identify interference between visible bodies or selected set of bodies. This is beta feature so to use this option beta options should be enabled. One can use ‘Share Topology’ in DM to identify interference. For the interference Share Topo creates additional bodies. Check these additional bodies to trace the location of interference.
