March 17, 2023 at 2:15 pm
FAQParticipantSay you have a geometry with design variables a = 1, b = 1, c = 1. And you want to add a scaled version of this to the same design with a = 3, b = 5, c = 2. You want to use the same variables to control two different geometries. The way to do this is through 3D components. Create a 3D comp of the geometry with variables a, b, c and insert it into the design that already uses same variables. Now you can independently control the geometries using same variable names.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
