Tagged: 2019 R3, composites, General, materials, mechanical-apdl, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantNU and PR are used to define the minor and major Poisson’s ratios respectively. Major and minor Poisson’s ratios are related by the following relationship: NUXY/EY = PRXY/EX ; NUXZ/EZ = PRXZ/EX ; NUYZ/EZ = PRYZ/EY
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
