Tagged: 2019 R1, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIn the Worksheet based Named selection on can create named selection for bodies with a specific material. Entitiy type: Body Criterion: Material Operator:Equal Value: select material in the dropdown menu
