How to get rid of the followingError: Assembly Failed. Error assembling pmdb and acmo files : Max Node Id is not correct. This is on workbench project which had model assemblies that have been run successfully before.
Tagged: 18.2, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantA work around for this can be by making a simple change in the upstream cell of sub-assembly to force an update in the assembly. (for example do suppress and then unsuppress a body). Once the cells in sub-assembly need update, update them. And then refresh and update the assembly.
