How to get effective damping in Mechanical APDL for a given mode when multiple materials are involved?
June 6, 2022 at 9:58 am
FAQ
ParticipantEffective damping ratio of mode n can be retrieve with *GET:
*GET, Par, MODE, n, DAMP
In addition, strain energy per material after the modal analysis:
/POST1
SET,1,jj !jj is the desired mode number
*DO,ii,1,nbmat !nbmat is the maximum number of material
ESEL,S,MAT,,%ii%
ETABLE,energy%ii%,SENE
ALLSEL
*ENDDO
SSUM
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
