January 25, 2023 at 7:34 am
FAQParticipantANSYS KM# 2041347 shows how RBD commands can be used to get reaction force on a contact. However, These points are important for multiple contacts: 1. There’s only one contact allowed per body in RBD analysis. 2. For multiple contacts, slice bodies and connect with fixed body-body joints. 3. Do not place multiple bodies in the same part for connected mesh, when using a contact on each body. 4. Alternatively, one can select multiple target face locations on the same body for one contact.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
