March 17, 2023 at 8:59 am
FAQParticipantTo get ANSYS Topology Optimization ACT for v17.x you will need to download it from the Customer Portal. Downloads > ANSYS ACT Application Store 17. You’ll then be in the ACT store. You should see several Ansys Topology Optimization v1. Download and install the version that matches your release of ANSYS.
