How to fix blurry fonts when using the “reverse video” setting in Mechanical APDL 8.1 through PlotCtrls > Hardcopy > to File?
Tagged: 17, General, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 322030.pdf
