Tagged: General, mechanical, N/A, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantSolution: Enable it at: Tools -> Options -> Mechanical -> Export -> Include Node Location Then, just run any simulation with deformation results, for example. And then right-click the results and export them to a text file.
