Tagged: 18.2, General, mechanical, modeling-and-meshing, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantOne can export undeformed model from Workbench Meshing in .pmdb format. This .pmdb file can be read into Spaceclaim or DesignModeler. To export the geometry, in Mechancial structure tree, right click on Geomtry -> select ‘Export’. Save the model in .pmdb format.
