How to export result to avi files? Why getting error message when trying to save the animation to window avi file.
Tagged: 18, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantPlease check to be sure you are not using a Windows Aero Theme? If so please go to the Control Panel (under Appearance and Personalization) and change to a Windows Basic theme. The Aero Themes are known to interfere with ANSYS graphics.
