June 5, 2023 at 7:05 am
FAQParticipantFor this, insert a new Mechanical System in the Project Schematic page and connect Engineering data cell to Engineering Data for new system and then Solution cell to the Model cell of second system. You may need to Update the Solution/Results cells in first system. Now, once you open Mechanical in second system, you will get deformed shape/mesh for your further analysis.
