Tagged: 17, General, mechanical, structural-mechanics
May 15, 2023 at 8:33 am
SolutionParticipantThe attached presentation describes the procedure The contents of this knowledge article have been created by the engineers from Entuple India
1. Exporting%20deformed%20results%20from%20Ansys%2017.pdf
