How to evaluate the properties of RHT concrete with strength (say, 28MPa) different than RHT model for 35MPa available in ANSYS database?
March 17, 2023 at 8:59 am
FAQ
ParticipantOne need to re-calculate the bulk modulus for the concrete material with a different compression strength. RHT material parameters are all scaled to the compression strength. What one need to do is simply picking the 35MPa concrete material data set, changing the compression strength from 35 MPa to 28 MPa. Then every other parameters are automatically scaled.
