Tagged: 19, DPM Wall Film, fluent, fluid-dynamics, MP - Particle Tracking, multiphase
January 25, 2023 at 7:17 amFAQParticipant
The particle diameter after separation from edge equals the maximum of the film height on the face and the value of the rp-variable ‘dpm/film-separation-height. The default for ‘dpm/film-separation-height is 1E-5. You can change this, for example to 1E-4 by (rpsetvar ‘dpm/film-separation-height 1E-4) (dpm-parameters-changed)
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- What do “incomplete” DPM particle tracks mean?
- Simulation of Exhaust Gas Recirculation (EGR) Cooler with CFD
