How to define temperature dependent material? For example, a material model with a modulus that increases with heat up and increases further with subsequent cool down.
Tagged: 19.1, materials, mechanical, Special Purpose, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThere is no direct way to define a single material model with a modulus that increases with heat up and increases further with subsequent cool down. But there can be some work around for this; 1) One can try setting up a duplicate material set that represents the modulus during the cool down step? Then run LS1 for the heatup with mat1, execute EMODIF to change the material attribute number (=mat2) after heat up is complete and then restart at LS2 for the cooldown step. 2) Alternately, maybe one could program own material behavior via USERMAT.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
