March 17, 2023 at 1:11 pm
SolutionParticipantIn Explicit Dynamics shell doesn’t accept directly defined orthotropic material defined in Engineering Data. The workaround is to assign a linear elastic material (such as steel) to the shell and use layer section to assign the orthotropic material to shell. Please see attached example.
1. 2059830.zip
