Tagged: 19, mechanical, Multibody, structural-dynamics, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThis is doable with a command snippet below each condensed part (with APDL of course). Be careful, at this level we are only at the generation pass level, therefore the only supported command are the following ones : ALPHAD BETAD MP,ALPD MP,BETD TB,SDAMP,,,,ALPD TB,SDAMP,,,,BETD Basically, for a 2% damping occuring for instance at 100 hz, we might put BETAD,0.02/(Pi*100) below the condensed part. Please also keep in mind that the use pass is performed in RBD and all the existing damping coefficients (for instance “C” for any joint) are still available. Special damping features (in the use pass) need to be used and defined with python scripting only (because RBD solver context)
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
