April 5, 2023 at 2:31 pm
FAQParticipantIncreasing the default memory used by the application can be quite helpful. Please try the following steps: 1. Goto “C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R2Additive” in file explorer 2. Right click the short cut for additive and click properties. 3. Replace the target with: “C:Program FilesANSYS Incv194AddPrintANSYS Additive 19.4.exe” –js-flags=”–max-old-space-size=8192″ 4. Click OK and accept the permisions window that pops up Reopen the application from the short cut.
