How to deal with following error in ACP-Post “Stresses and strains for xxx elements are ignored because the result data does not fit to the corresponding elements or their layers.”
Tagged: 18.1, ANSYS Composite PrepPost, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThis Generally happens when ACP-Pre is assembled with other solid/shell part. So to fix this, turn off “Renumber Mesh Nodes and Elements Automatically” for Composite system in the properties of the assembly and re-solve the model
