Tagged: 18.2, General, mechanical, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantTo import the load history from XML file, XML file should be formatted and written in a specific structure. The procedure is explained in below website link http://www.padtinc.com/blog/the-focus/importing-and-exporting-ansys-mechanical-loads-as-xml-files If you have load history in excel sheet, the simplest way would be just copy paste the entire table as shown in attached image.
