Tagged: 19, bolt, hex, meshing, modeling-and-meshing, Multizone, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer the attachments to access the solution
1. 2053147.mp4
2. 2053147.zip
