March 17, 2023 at 8:59 am
FAQ
ParticipantThe following may be used to create a boundary curve to fill or replace a face: 1. Select two vertices and use the Blend command, to create a curve. The default result will be a straight line between the two points. 2. Define tangent conditions at each end using the Guides option within the Blend command. This will result in a boundary that matches the curvature of the adjacent faces.
