Tagged: 18.2, General, mechanical, Multiphysics and EMAG, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThis can be done using TCHG command. Insert a command object under the geometry for which the element type to be changed. In the command object write the command: ESEL, S, TYPE, , matid TCHG, SOLID236, SOLID237
