June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video, we will talk about how to define parameters in Excel and import them to Workbench. This feature can be very useful for cases where we need to define a complex relationship between input parameters that is not possible to do within Workbench directly.
