March 17, 2023 at 8:59 am
FAQParticipantWhen executing Autodyn with a subroutine in a parallel mode, each task will have and execute its own instance of the subroutine. In order to differentiate which task is executing the subroutine the user can check the variable MYTASK. In order to access this variable the user has to add the line USE mdpp, ONLY : MYTASK in the section with the USE statement of the subroutine of interest. If the user runs Autodyn with n cores, he will have n+1 processes: 1 master process and n slave processes. MYTASK will then have values between 0 (master process) and n (1-n is the range of the slave tasks).
