March 17, 2023 at 2:15 pm
FAQParticipantWhen exporting a Motor-CAD model to Maxwell, rotor speed is negative. In EM analysis it is not relevant, but in case of NVH analysis, rotor speed should be positive. However it can be easily change manually by modifying the vbs-script created by Motor-CAD: 1. Search for “Angular Velocity:=”, “-MachineRPM”, and change the value to “MachineRPM” 2. Search for “Winding Group” and change the current phase of windings 2 and 3: (360 – 120) –> (360 + 120) (360 – 240) –> (360 + 240) 3. Search for “Torque Plots”, and change the y-component: “-Moving1.Torque” –> “Moving1.Torque” Finally run the script in Maxwell as usual
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
