Tagged: 18, General, mechanical, structural-mechanics
August 25, 2023 at 12:16 pm
FAQParticipantTo assign different color to different bodies: Click on the body from Geometry tree, in the ‘Details View’ of the body, click on “Graphics Properties”, and change “Color” to the color you prefer. Please see the attached image for reference. If there are too many bodies then to locate the body in the tree: Select the body from the graphics window, right click >> Go to >> ‘Corresponding body in the Tree’
